1. [email protected]
  3. Monday, 13 December 2021
i have a problem when i want to create or edit an article Joomla on the frontend.
i have tested with severals editors WYSIWYG (TinyMCE and JCE) it is the same. When the page loading i can't modify the fields. The page is frozen. I can't do anything ...
If I test with the minimum number of plugins and I deactivate JCH Optimize, it's the same. Each time I purge the browser cache and tried on several web browsers.
If i test with another template it's ok (a native template of Joomla for example).
I send you access code of my project.
I haven't seen a changelog for this template. Maybe it's enough to download the latest version of the template?
I also noticed that the anchors don't work: #editor, #images, #metadata, ...
Here is one of the answers from the developer of the JCE editor:
The tabs are not working as expected because they use Bootstrap css and your template does not appear to be loading Bootstrap as required.
Please speak to the template developer about this.
If Bootstrap is required by your extension then it is really up to that extension to load its dependencies. Regardless, you could try loading Bootstrap from a CDN. Try adding the following to the custom code field of your template settings...
<link href="https://cdn.jsdelivr.net/npm/[email protected]/dist/css/bootstrap.min.css" rel="stylesheet" integrity="sha384-1BmE4kWBq78iYhFldvKuhfTAU6auU8tT94WrHftjDbrCEXSU1oBoqyl2QvZ6jIW3" crossorigin="anonymous">
<script src="/https://cdn.jsdelivr.net/npm/[email protected]/dist/js/bootstrap.bundle.min.js" integrity="sha384-ka7Sk0Gln4gmtz2MlQnikT1wXgYsOg+OMhuP+IlRH9sENBO0LRn5q+8nbTov4+1p" crossorigin="anonymous"></script>
We have just updated the Layla template resolving the following issues...
Version 1.0.7 - 1st January 2021
# Fix frontend editing tabs
# Fix frontend editing modal overlay
I just downloaded the Layla template in my J51 profile!
Then installed on one of my J4 websites. It still shows version 1.0.3 ...
Hello Ciaran
can you tell us which files you updated in the template?
At the risk of removing some customization.
