I followed these instruction below in the Tutorials but the presets still do not load on my add-on sites nina4.wouterturkenburg.nl and layla4.wouterturkenburg.nl
I have tried it many time, cleaning the browser cache every time: no results.
Templates are installed with the latest Joomla demo-installers zip files.
- Why do the presets not load?
- Is there another way of loading them, other than as explained in the Tutorials?
Thanks in advance, Wouter
From your Joomla administration navigate to your template style settings (Extensions -> Templates -> Styles -> [YourTemplateStyle]).
For this tutorial rather than overwriting your current template settings, we are going to create a new template style in to which we will load the new settings. Enter the Style Name of your choice and hit Save as Copy.
In the Details tab of your newly created template style, select the example style of your choice from the Load Preset dropdown.
Click the Load Preset button. Please note that this option is irreversible. Once this button is clicked the new settings from the preset will be loaded and saved, overwriting any current settings.
Your new template style has been created with the same settings as the ‘example style’ of your choice.
