1. Turkenburg
  4. Tuesday, 04 October 2022
I followed these instruction below in the Tutorials but the presets still do not load on my add-on sites nina4.wouterturkenburg.nl and layla4.wouterturkenburg.nl
I have tried it many time, cleaning the browser cache every time: no results.
Templates are installed with the latest Joomla demo-installers zip files.
- Why do the presets not load?
- Is there another way of loading them, other than as explained in the Tutorials?
Thanks in advance, Wouter
From your Joomla administration navigate to your template style settings (Extensions -> Templates -> Styles -> [YourTemplateStyle]).
For this tutorial rather than overwriting your current template settings, we are going to create a new template style in to which we will load the new settings. Enter the Style Name of your choice and hit Save as Copy.
In the Details tab of your newly created template style, select the example style of your choice from the Load Preset dropdown.
Click the Load Preset button. Please note that this option is irreversible. Once this button is clicked the new settings from the preset will be loaded and saved, overwriting any current settings.
Your new template style has been created with the same settings as the ‘example style’ of your choice.
  1. http://nina4.wouterturkenburg.nl
  2. http://layla4.wouterturkenburg.nl
Hi Wouter
Loading the template style preset will only load the values for that style in to your template settings. Sorry to say, this does not include the creation of any modules that are displayed in the template demo (eg. https://www.joomla51.com/demo/0173/index.php/example-styles/example-styles-1). This includes the header images as these are through the LayerSlideshow module.
Dear Ciaran, Thank you for looking into my problem. I have enlarged the limits in the php setting of my provider, in th JCE custom settings and in the Joomla 4 menu setting. Uploading files do noy seem to be the problem. Also, the only file I uploaded has the same sizes as the files in the example styles.
What confused me is that the example styles chosen do not appear if I change from default to e.g. example style 1. The showcase picture does not change accordingly and also some modules belonging to the example style chosen, do not appear. `Is this an Joomla 4 issue, my website issue or do I do something wrong?
I have send the login credentials to you so I would like to know what you have found.
Kind regards, Wouter
Thank you Wouter
There is what looks like a race condition with the masonry script. The masonry is only applied after all your images are loaded however this doesn't appear to happen due to your image sizes. Currently, they seem to stop loading at almost 50mb. Could you try reducing your images sizes and see if this improves things as the current image sizes make the loading of your site very slow (on this side the page never fully loaded for me, eventually timing out)..
Hi Wouter
Updating your template to the latest download should resolve this issue for you. For details on updating your template may I suggest the following article.. https://joomla51.com/tutorials/joomla-basics/updating-your-joomla-template
If the issue persists after updating, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
