I'm using the latest version of Novah for Joomla 4.
The template tries to call the following css file:
example.org/media/templates/media/vendor/joomla-custom-elements/css/joomla-alert.css
This generates an error (404) because the path is incorrect. It should probably be:
http://example.org/media/vendor/joomla-custom-elements/css/joomla-alert.css
This file exists.
I think this is a bug. Where do I have to make the correction?
- Joomla51Wunder
- Saturday, 20 August 2022
@ciaran I have exactly the same problem but with template J51 - Bianca - Joomla 4 Version: 1.1.10
Can you point me to the solution to fix this problem please?
Thank you for pointing us in the direction of the cause of this issue. I have just created an update to the Novah template which should hopefully resolve this issue. For details on updating your template may I suggest the following article.. https://joomla51.com/tutorials/joomla-basics/updating-your-joomla-template
If the issue persists after updating, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
Hi!
I reinstalled the template (Novah-J4 Version 1.1.3). But the problem is not solved.
Now I did some tests. There is the following directory:
media/templates/site/j51_novah/css/vendor/joomla-custom-elements/....
There are 3 files in there:
joomla-alert.css
joomla-alert.min.css
joomla-alert.min.css.gz
First line:
@import "../../../../../media/vendor/joomla-custom-elements/css/joomla-alert.css";
If I change this line, the file joomla-alert.css is called correctly
@import "../../../../../../../media/vendor/joomla-custom-elements/css/joomla-alert.css";
I have no idea why this works in the quickstart install and I need to change it in my joomla install.
The Quickstall installation may be older. Maybe that's why they are different.
joomla-alert.css
First line:
This is a strange one as two CSS files that are not found exist within the demo installer package and the template itself.
As a bit of a long shot, could I ask you to try installing the template package (j51_novah_j4.zip) via your extensions manager which should re-add this file for you.
The problem occurs on all menu items, e.g. single article, category blog, J4 contact form...
I installed the quickstart package as a test. Everything seems fine there:
/templates/j51_novah/css/vendor/joomla-custom-elements/joomla-alert.min.css?0.2.0 (200)
/media/vendor/joomla-custom-elements/css/joomla-alert.css (200)
However, when I install the J51_Novah template in Joomla 4.1.5, one path is incorrect:
/media/templates/site/j51_novah/css/vendor/joomla-custom-elements/joomla-alert.min.css?0.2.0 (200)
/media/templates/media/vendor/joomla-custom-elements/css/joomla-alert.css (404)
Unfortunately, I can't provide a URL at the moment.
But it seems that the same problem exists in the Layla template as well: https://www.joomla51.com/forum/little-issues-in-j4-nina-and-j4-layla
There is also a link there.
Would you have a URL to an example of this issue? Could you detail the menu item type where the issue is present?
