1. Kiso
  3. Sunday, 04 December 2022
When I install joomla 4, Novah51 and the installation is finished, this comes up instead of admin. I attached the picture. What could be the problem?
The installation went as usual in the demo installer folder. joomla_novah.png
Hi Ciaran -
Hi -
I got the same error from the Nina J4 1.1.11 Demo Installer and the Hannah J4 1.0 Demo Installer. I found a solution in Github that worked for me:
After you do your installation,.go into your installation files and delete the file "administrator/cache/autoload_psr4.php". I used FileZilla to delete the file.
Some people on Github said that file deletion worked and some said it didn't. It worked for me. https://github.com/joomla/joomla-cms/issues/38474
Mark
1. Does the contents of your ../plugins/behaviour/taggable folder match the contents here...https://github.com/joomla/joomla-cms/tree/4.2-dev/plugins/behaviour/taggable
2. Do you extract your zip first and upload or upload first and then extract? The latter would be favourable
Ah thank you Mark
This issue has come up multiple times recently and we have been at a bit of a lost in both replicating and finding a solution.
Thanks again.
