1. Kiso
  3. Sunday, 04 December 2022
When I install joomla 4, Novah51 and the installation is finished, this comes up instead of admin. I attached the picture. What could be the problem?
The installation went as usual in the demo installer folder. joomla_novah.png
1. Does the contents of your ../plugins/behaviour/taggable folder match the contents here...https://github.com/joomla/joomla-cms/tree/4.2-dev/plugins/behaviour/taggable
2. Do you extract your zip first and upload or upload first and then extract? The latter would be favourable
Hi Ciaran -
Hi -
I got the same error from the Nina J4 1.1.11 Demo Installer and the Hannah J4 1.0 Demo Installer. I found a solution in Github that worked for me:
After you do your installation,.go into your installation files and delete the file "administrator/cache/autoload_psr4.php". I used FileZilla to delete the file.
Some people on Github said that file deletion worked and some said it didn't. It worked for me. https://github.com/joomla/joomla-cms/issues/38474
Mark
Ah thank you Mark
This issue has come up multiple times recently and we have been at a bit of a lost in both replicating and finding a solution.
Thanks again.
