1. [email protected]
  3. Thursday, 11 July 2013
Any ideas how to make the whole site a white background without the grey shadow?
Also how do you make the menu vertical in sidecol a?
cheers,
G
Hey thanks Ciaran,
I ended up using the substance template which didnt have any issues getting the white background.
The side menu help is much appreciated!
cheers
Hi G
Would you have a URL to an example of the grey shadow?
To float your menu items vertically in the sidecol-a module positions try adding the following to the Custom CSS field of your templates parameters...
#sidecol_a ul li {
float: left !important;
#sidecol_a ul li a {
margin-top: 0 !important;
