Hy,
I'm trying to build a multi language site using your template oxygen (comercial version). At first I used free version of oxygen and different menus for each language worked fine with language switcher and they displayed in hornav according to the language chosen. But then I purchased the commercal version and now I have this problem: in templates parameters I can now choose only one menu to display under the Hornav Menu Settings and other menus (for other languages) now don't display when I switch to another language. How can I solve this problem.
I would also like the flags of language switcher to be displayed in main menu (hornav) or above it in the right corner.
Best regards
