1. rebelojose
  4. Monday, 12 February 2024
Dear Ciaran,
how can I put the navigation buttons at the top instead of being in the footer?
(image attach)
regards
Jose
Hi Jose
Would you have a URL to an example of your module?
dear Ciaran,
tks for reply
url above
  1. https://dev.rebellicatm.com/casamalm/index.php/en/testimonials
Hi Jose
.j51-testimonials {
display: flex;
flex-direction: column;
.j51-testimonials .j51-nav-dots {
order: -1;
  3. # 3
tks Ciaran, it is perfect
regards
Jose
  3. # 4
Dear Ciaran,
is is about buttons per page on testimonials module.
for example I have 8 testimonials and 2 Columns Per Slide, so he have 4 pages and 8 buttons, but is only need 4 buttons, this 4 buttons extra are doing nothing and it is confusing for visitors -- the same happened for 3/4/5/6 Columns Per Slid - it is always 8 buttons
it is possible hide this buttons that they are of no use?
regards
Jose
  1. https://www.rebellicatm.com/index.php/en/services-en
  3. # 5
Hi Jose
  3. # 6
