1. rebelojose
  4. Monday, 12 February 2024
Dear Ciaran,
how can I put the navigation buttons at the top instead of being in the footer?
(image attach)
regards
Jose
Hi Jose
Dear Ciaran,
is is about buttons per page on testimonials module.
for example I have 8 testimonials and 2 Columns Per Slide, so he have 4 pages and 8 buttons, but is only need 4 buttons, this 4 buttons extra are doing nothing and it is confusing for visitors -- the same happened for 3/4/5/6 Columns Per Slid - it is always 8 buttons
it is possible hide this buttons that they are of no use?
regards
Jose
  1. https://www.rebellicatm.com/index.php/en/services-en
tks Ciaran, it is perfect
regards
Jose
  3. # 3
Hi Jose
.j51-testimonials {
display: flex;
flex-direction: column;
.j51-testimonials .j51-nav-dots {
order: -1;
  3. # 4
dear Ciaran,
tks for reply
url above
  1. https://dev.rebellicatm.com/casamalm/index.php/en/testimonials
  3. # 5
Hi Jose
Would you have a URL to an example of your module?
  3. # 6
