1. Worklive
  3. Wednesday, 11 December 2024
Hello, from mobile the parent entries do not work: if I click on one of it it opens the subheadings for me, but in my case the parent entries contain a page.
From desktop everything works, only from mobile does not work.
Try to open for example the item "Strumenti" from desktop and then from mobile.
Login:
User: test
Pass: test123er456@
  1. https://www.essentialink.it/choralcreation/index.php/strumenti-esoterici
Hi Ciaran, thank you very much, now works!
Hello FrancW, I followed the instructions but it still does not work on the mobile.
Try it yourself and tell me if it works now..
Hi, news?
Could I ask you to allow us access to your extension manager so we can update your template?
I just enabled you access
This issue should be now resolved. Clicking the text will now open the link, while clicking the dropdown icon will open the menu.
Hi Ciaran, it now works thanks.
Can you write me the change you made here?
Because I moved my site to a new domain and on this new one the menu does not work because I moved it before your change.
In more recent version of Joomla, template assets are moved to the media folder so any changes made as suggested in https://joomla51.com/tutorials/template-customization/mobile-menu-linking-parent-items would also have to be applied to the corresponding file in your ../media folder.
Perfect thanks, now it works!
I noticed however that from mobile if I click on the last menu item, it does not work (it is not clickable).
All the others works.
Can you help me?
  1. https://www.essentialcreation.it/index.php/inner-creation-home
Hello, please I need to solve the problem, my site must be online by this week!
Did you see that there is an uncaught JavaScript error on your site? May be the cause for the issue.
Hi Dautrich, I don't see it, what error are you talking about? can you help me solve?
Hi Dautrich, I didn't understand what those files I see in red center with the problem generated in javascript.
Can you give me more information to solve the problem?
I'm not an expert in programming..
.slicknav_menu {
z-index: 100;
