1. mediafrog
  4. Friday, 16 June 2017
hi ciaran,
please have a look here
https://alternative-homoeopathie.ch/index.php
is it possible to show the top menu in position header 1 also in responsive layout? I can't select it in th options. and how can I delete the points before the menu items?
thanks again for your help.
regards
grit
Hi Grit
.header-1 li, .header-2 li {
list-style: outside none none;
.header-1, .header-2 {
display: inline-block !important;
padding-top: 0 !important;
hi ciaran,
thank you very much. It works fine now.
regards
grit
