1. maolmcuait
  3. Monday, 29 July 2019
I'm using the Magnolia template. I don't want to use the Header Image(s) under the General Menu in the template, instead I have installed the slideshow module from a recent template purchased and allocated it to slideshow-a position. It works perfectly and I can put text over the slideshow etc.. However my dropdown menu items don't show unless I disable this slideshow module, not sure if they are on the same levels or why it prevents the menu items showing. Any idea please?
Would you have a URL to an example of this issue? It sounds like a z-index issue where the dropdown is appearing behind your slideshow.
Yes it is Ciaran, I was thinking that with the levels, I need the menu on layer 9999 and slideshow in position slideshow-a lower, so just wondering what's the best way to allocate the levels for both with the z-index.
Maol
deleted
Doesn't matter I'm going to try something else, stuck for time, thanks anyway
