1. maolmcuait
  3. Monday, 29 July 2019
I'm using the Magnolia template. I don't want to use the Header Image(s) under the General Menu in the template, instead I have installed the slideshow module from a recent template purchased and allocated it to slideshow-a position. It works perfectly and I can put text over the slideshow etc.. However my dropdown menu items don't show unless I disable this slideshow module, not sure if they are on the same levels or why it prevents the menu items showing. Any idea please?
Doesn't matter I'm going to try something else, stuck for time, thanks anyway
Would you have a URL to an example of this issue? It sounds like a z-index issue where the dropdown is appearing behind your slideshow.
Yes it is Ciaran, I was thinking that with the levels, I need the menu on layer 9999 and slideshow in position slideshow-a lower, so just wondering what's the best way to allocate the levels for both with the z-index.
Maol
deleted
