1. maggy3003
  3. Thursday, 13 August 2015
on widescreens sees the header area like this (see attachment).
The edge effect artifact.
Do you have a solution?
Maggy
To amend try adding the following to your Custom CSS field...
#header_bg::after {
bottom: -90px;
Unfortunately, it solves the problem incorrectly. The artifacts remain.
If I increase the value, the oblique line is no longer available. Too bad.
In addition, then have the problem in the base area.
Any Idea?
Maggy
Hi Maggy
May I ask at what resolution are you viewing your site? What do you mean by 'artifacts'?
When I see the page on my 27 "iMac in full screen mode, this problem is visible
Artifacts = the line looks ragged (see attachment). Your Demo-Site looks also.
Presuming you are using a webkit browser(Chrome/Safari) which can have issues with CSS skewed elements such as this, try adding the following to the Custom CSS field of your templates parameters...
#header_bg::after, #container_base::after {
-webkit-backface-visibility: hidden;
What is your screen resolution (eg. 2100px * 1400px) so we can try and replicate the other issue?
I have also bought the Madison template and facing the same problem.
See attachments
HI Andreou
Are you referring to a jagged edge on the skewed background elements of the template? Have you tried the above suggest fix for this issue?
Yes I copy-paste the code to the template - custom css and pressed the YES button.
But is still not fixed.
Thank you Andreou
I possibly have misunderstood your issue however I am unable to replicate the issue originally reported in this post with your site in any of the webkit browsers (Chrome & Safari). The skewed background in each of these browsers is appearing anti alias with no jaggedness.
I installed the update. The jagged edge of the skewed background elements is, depending on the monitor resolution, still. So I can live well ;)
The other problem is solved. Many thanks!!!
Maggy
