on widescreens sees the header area like this (see attachment).
The edge effect artifact.
Do you have a solution?
Maggy
- maggy3003
- Thursday, 13 August 2015
I installed the update. The jagged edge of the skewed background elements is, depending on the monitor resolution, still. So I can live well
The other problem is solved. Many thanks!!!
Maggy
Maggy
Thank you Andreou
I possibly have misunderstood your issue however I am unable to replicate the issue originally reported in this post with your site in any of the webkit browsers (Chrome & Safari). The skewed background in each of these browsers is appearing anti alias with no jaggedness.
Yes I copy-paste the code to the template - custom css and pressed the YES button.
But is still not fixed.
HI Andreou
Are you referring to a jagged edge on the skewed background elements of the template? Have you tried the above suggest fix for this issue?
I have also bought the Madison template and facing the same problem.
See attachments
See attachments
Presuming you are using a webkit browser(Chrome/Safari) which can have issues with CSS skewed elements such as this, try adding the following to the Custom CSS field of your templates parameters...
What is your screen resolution (eg. 2100px * 1400px) so we can try and replicate the other issue?
#header_bg::after, #container_base::after {
-webkit-backface-visibility: hidden;
}What is your screen resolution (eg. 2100px * 1400px) so we can try and replicate the other issue?
When I see the page on my 27 "iMac in full screen mode, this problem is visible
Artifacts = the line looks ragged (see attachment). Your Demo-Site looks also.
Hi Maggy
May I ask at what resolution are you viewing your site? What do you mean by 'artifacts'?
- # 9
Unfortunately, it solves the problem incorrectly. The artifacts remain.
If I increase the value, the oblique line is no longer available. Too bad.
In addition, then have the problem in the base area.
Any Idea?
Maggy
Any Idea?
Maggy
- # 10
To amend try adding the following to your Custom CSS field...
#header_bg::after {
bottom: -90px;
}Ciarán
- # 11
