I am having a problem customizing the hornav menu on the London template. It used to be so easy to customize the J51 templates and now I'm finding them to be more and more problematic and limiting.
I have tried for over an hour to change the menu to color to be transparent. I have a background image on the header and I would like it to show through the menu. However no matter what I do I am stuck with having to specify a color. I've tried rgba, I tried searching the CSS, and all to no avail.
I then thought I'd take a look at another template - Scarlett.... well - I tried just inspecting to see if I could change that one and I could as long as I didn't put an image in it and then I was again stuck with a white menu.
Please help me.
I will need to send you the access as this is not a live site.
