Hi Ciaran, using Kodaline I have a problem after using the "cookie consent script" of http://www.cookiebot.com. I entered the script lines within the custom code filed of the template paramenters on each used template style. I also entered the Google Analytics Script within the custom code field of the Homepage Template Style after the Cookiebot Script lines.
Prior giving consent to save cookies at all AND when giving consent to only necessary cookies: On mobile view (phone and tablet) the mainmenu didn't open after touching the bars icon on the top right corner. It seems that the Cookiebot Script blocks not only all scripts (what it surely should do!) but also the function of opening the mainmenu.
To find a work around for the moment I left the "Google Analytics script lines" within the template paramenters homepage style, but entered the "Cookiebot script lines" into the header of the index.php of my Kodaline template.
Is there a better way to use both Scripts within the template parameters of Kodaline and make the main menu work properly? Thanks in advance! Robert
