1. Mol4
  4. Wednesday, 27 July 2022
On my clients testsite there is an issue with the following:
  • the sidecolumn doesn't stack on mobile
  • the background of the logo is going to far to the right (on mobile)
  • because of that the SlideOut mobile Menu can't be used
I've tried a few things but no luck sofar.
Can you please assist in solving these problems?
Thanks!
Greetings, Ton
Thanks for the update and the CSS-code!
This helps just fine :D
Greetings,
Ton
Hi Ton
1. Updating your template to the latest download should resolve this issue for you. For details on updating your template may I suggest the following article.. https://joomla51.com/tutorials/joomla-basics/updating-your-joomla-template
If the issue persists after updating, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
2. / 3. To amend you can add the following to the Responsive Custom CSS fields within the General -> Responsive Options tab of your template settings. For more details on using these fields may I suggest the following article... https://joomla51.com/tutorials/template-parameters/applying-custom-css-to-a-screensize-device
(edit to taste)
.logo {
padding-right: 0;
.logo h1 a {
font-size: 2.2rem;
