1. Mol4
  4. Wednesday, 27 July 2022
On my clients testsite there is an issue with the following:
  • the sidecolumn doesn't stack on mobile
  • the background of the logo is going to far to the right (on mobile)
  • because of that the SlideOut mobile Menu can't be used
I've tried a few things but no luck sofar.
Can you please assist in solving these problems?
Thanks!
Greetings, Ton
Hi Ton
1. Updating your template to the latest download should resolve this issue for you. For details on updating your template may I suggest the following article.. https://joomla51.com/tutorials/joomla-basics/updating-your-joomla-template
If the issue persists after updating, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
2. / 3. To amend you can add the following to the Responsive Custom CSS fields within the General -> Responsive Options tab of your template settings. For more details on using these fields may I suggest the following article... https://joomla51.com/tutorials/template-parameters/applying-custom-css-to-a-screensize-device
(edit to taste)
.logo {
padding-right: 0;
.logo h1 a {
font-size: 2.2rem;
Thanks for the update and the CSS-code!
This helps just fine :D
Greetings,
Ton
