Hi Ciarán
Is there a way to "Article Background" transparent (semitransparent) is set to? Unfortunately I can only find "Article Background Color"
Thank you for your help
Peter
It should be clear only the contents of the "Transparent" page.
The entry in Custom CSS has no effect (opacity: 0.5; or background-color: rgba (250, 250, 250, 0.8)
Thanks for your help
Peter
