1. pschmili
  4. Monday, 01 August 2016
Hi Ciarán
Is there a way to "Article Background" transparent (semitransparent) is set to? Unfortunately I can only find "Article Background Color"
Thank you for your help
Peter
Hi Peter
Would you have a URL to an example fo the area you wish to make transparent?
http://joomla.pschmili.de/transparent
It should be clear only the contents of the "Transparent" page.
The entry in Custom CSS has no effect (opacity: 0.5; or background-color: rgba (250, 250, 250, 0.8);)
Thanks for your help
Peter
Hi Peter
Presuming I understand you correctly try adding the following to the Custom CSS field of your templates parameters (edit to taste)...
#container_main {
    background-color: rgba(250, 250, 250, 0.5);
Hallo Ciarán
Thanks for the help and support. I had the "#" Lost.
Peter
Happy to help! :)
