1. alfoto
  3. Thursday, 04 December 2014
I'm using J51_slideshow with template Cashmere. The web site is in a subfolder.
I'm adding a CDN resource to this site.
I have implemented cdnforjoomla and it works fine for all images in the web but the slideshow isn't working. Slideshow images are loaded from images/slideshow folder.
Any help will be appreciated.
Great :)... thank you for the update.
Just updated JCH Optimizer to last version 4.1.4 and problems seem to be solved ;)
This remembers me how important it is to have always the last version installed.
Will apply now changes to live site, hope it goes also well.
I believe the problem is on JCH Optimizer.
I have made a test copy of the site, once I enable the Optimizer plugin the slideshow doesn't work.
Will test several settings now at JCH to find the best out.
  3. # 3
What CDN resources do you wish to add to your site? Presuming you are using Joomla 3.x ensure that you have jQuery disabled within the slideshow modules parameters.
  3. # 4
