1. alfoto
  3. Thursday, 04 December 2014
I'm using J51_slideshow with template Cashmere. The web site is in a subfolder.
I'm adding a CDN resource to this site.
I have implemented cdnforjoomla and it works fine for all images in the web but the slideshow isn't working. Slideshow images are loaded from images/slideshow folder.
Any help will be appreciated.
What CDN resources do you wish to add to your site? Presuming you are using Joomla 3.x ensure that you have jQuery disabled within the slideshow modules parameters.
I believe the problem is on JCH Optimizer.
I have made a test copy of the site, once I enable the Optimizer plugin the slideshow doesn't work.
Will test several settings now at JCH to find the best out.
Just updated JCH Optimizer to last version 4.1.4 and problems seem to be solved ;)
This remembers me how important it is to have always the last version installed.
Will apply now changes to live site, hope it goes also well.
  3. # 3
Great :)... thank you for the update.
  3. # 4
