1. crimle
  4. Monday, 12 December 2022
I am using J51_Skylar_J4 1.1.7. We have a 2-columns blog. This first column is ok. But the second column does not respect the max-width of the template. I don't find out why.
Thank you and kind regards
Chris
  1. https://j4.ttcuster.ch/galerie/sportanlaesse
Hi Chris
Thank you for the update. Could you try the following instead...
.blog-items.columns-2 {
grid-template-columns: 50% 50%;
column-count: auto;
column-gap: 1rem;
I'm afraid I have to come back to this topic again. The css code you proposed above has the side effect of enforcing the two-column blog layout on mobile screens as well. So I added a media query in order to avoid these two columns:
@media only screen and (min-width: 959px) {
column-count: auto;
column-gap: 1rem;
I hope I did it right?!
The unwanted two-column layout for mobile screens needs to be taken into account, if you are planning to implement this amendment to a future version of this template.
Chris
Hi Chris
This results in the column extending slightly less far beyond the template border. But it's still too wide and doesn't really fit within the boundaries of the template. Or rather: it does not respect the padding of the template border.
Chris
Yes! It is perfect now.
Chris
Hi Chris
Thank you for sharing your solution. That looks perfect, you are ensuring the CSS is only applied to screensizes above 959px in width.
