1. crimle
  4. Monday, 12 December 2022
I am using J51_Skylar_J4 1.1.7. We have a 2-columns blog. This first column is ok. But the second column does not respect the max-width of the template. I don't find out why.
Thank you and kind regards
Chris
  1. https://j4.ttcuster.ch/galerie/sportanlaesse
Hi Chris
Thank you for sharing your solution. That looks perfect, you are ensuring the CSS is only applied to screensizes above 959px in width.
I'm afraid I have to come back to this topic again. The css code you proposed above has the side effect of enforcing the two-column blog layout on mobile screens as well. So I added a media query in order to avoid these two columns:
@media only screen and (min-width: 959px) {
.blog-items.columns-2 {
grid-template-columns: 50% 50%;
column-count: auto;
column-gap: 1rem;
I hope I did it right?!
The unwanted two-column layout for mobile screens needs to be taken into account, if you are planning to implement this amendment to a future version of this template.
Chris
Yes! It is perfect now.
Chris
Hi Chris
Thank you for the update. Could you try the following instead...
column-count: auto;
column-gap: 1rem;
This results in the column extending slightly less far beyond the template border. But it's still too wide and doesn't really fit within the boundaries of the template. Or rather: it does not respect the padding of the template border.
Chris
Hi Chris
