we are using the Scarlett template on a bigger project.
The main menu does have a sencond level but this is show on the lower end of the submenu (=> file submenu_01,jpg).
To be sure that there is a problem I installed the template on a very small new project. Same problem here (=> file submenu_02,jpg).
Do you have any idea how I can get the sub-submenu to the correct positon?
Thanks in advance.
