1. Oliver
  4. Wednesday, 11 January 2017
we are using the Scarlett template on a bigger project.
The main menu does have a sencond level but this is show on the lower end of the submenu (=> file submenu_01,jpg).
To be sure that there is a problem I installed the template on a very small new project. Same problem here (=> file submenu_02,jpg).
Do you have any idea how I can get the sub-submenu to the correct positon?
Thanks in advance.
Thank you Ciaran.
If found the style code in the nexus.css which fixed the problem.
Thank you very much.
Regardfs
Oliver
We have updated your template to the latest download and the menu is now displaying correctly.
