1. Hammur
  4. Saturday, 11 October 2014
Hi, is it not possible to have a working footer menu, if there is other modules also positioned at the footer menu position?
I converted the footer menu of the J51Polaris template to a module position from the template parameters, so that I could place a login/user panel module (Plus User Panel) in the corner to the right of the menu.
The issue I'm getting with this, is that my footer menu module somehow gets disabled or non-functional. The footer menu from the module and it's menu items show up just fine, but I can't click on any of the menu's.
The user panel module does however work fine.
If I unpublish the Plus User Panel module, leaving the menu module alone in the footer menu position, then its menu's work fine.
Link to page: http://kfumlokin.konsult.fo
When you convert footer menu to a module position the footer menu will be no longer available to you. Have you considered simply creating a new menu module (Extensions -> Module Manager -> New -> Menu) in the footermenu module position along with any other modules you wish in this area?
Hi, thanks. Created a second menu module for the foot menu and unpublished the first one and it works fine.
Except the modules get aligned vertically instead of just aligning horizontally next to each other, not sure if it's possible though?
Didn't really strike my head to try and make a second menu module, since I found it little weird that the first menu module wouldn't
Would you have a URL to an example of the vertical menu?
Here: http://kfumlokin.konsult.fo/
At the bottom of the page, you'll see the Menu module with the items: Forsíða | Skótar
And then the second module "Innrtita" is floated to the right, but is above 'Forsíða | Skótar'. Can see this clearly if you float it left.
To amend could you try adding the following to the Custom CSS field of your templates parameters...
#footermenu .module_margin {
position: relative;
#plusl {
position: absolute;
right: 0;
