Hi, is it not possible to have a working footer menu, if there is other modules also positioned at the footer menu position?
I converted the footer menu of the J51Polaris template to a module position from the template parameters, so that I could place a login/user panel module (Plus User Panel) in the corner to the right of the menu.
The issue I'm getting with this, is that my footer menu module somehow gets disabled or non-functional. The footer menu from the module and it's menu items show up just fine, but I can't click on any of the menu's.
The user panel module does however work fine.
If I unpublish the Plus User Panel module, leaving the menu module alone in the footer menu position, then its menu's work fine.
Link to page: http://kfumlokin.konsult.fo
- Hammur
- Saturday, 11 October 2014
