1. jcnp
  3. Sunday, 08 July 2012
Hi!
I'm using J51 Oxygen Joomla template and I just wanted to ask why the print icon doesn't show despite having it set on "show."
Please advise on what I should be checking or looking for. Any help will be greatly appreciated. For reference, here's the draft webiste: http://francishousecenter.org/
Thank you.
Sincerely,
John
Hi John
May I suggest sending temporary administration access to your Joomla installation to [email protected] so we can have a look at your Joomla settings.
Hi Ciaran!
I've registered you as a guest admin. Please advise if you got the invite.
Thanks.
John
It appears your icons were simply disabled via the menu items parameters. I have enabled them for the homepage (Menus -> Main Menu -> Home -> Article Options), you may need to do the same for the rest of your menu items.
  3. # 3
I am using the same template and the problem I have is a bit different - Only one icon shows if both print and email icons are enabled from the global article options (all my menus are set to use Global setting). If both enabled, only email icon shows up, If I disable the email icon, then the print icon shows up. Looks as if there is no space to show both icons. When I switch to another template, I do see both icons in all articles.
Unfortunately, I am still developing the website and it is not accessible from the internet yet.
I am using Joomla! 2.5.4. Any idea what might be causing this?
Thanks in advance for the help.
  3. # 4
Hi euealt
Its hard to say for sure the cause without access to your site but is this issue present on all browsers or just one particular browser?
  3. # 5
Hmm .. I just checked it on 3 different browsers and it works only on Firefox, on IE and Chrome only the Email icon is displayed.
  3. # 6
May I suggest adding the following CSS to the Custom CSS of your templates parameters...
[code type=css].actions li {margin-top: -10px;}[/code]
  3. # 7
Thanks Ciaran!! Just added the CSS and I see both icons in all the three browsers now.
  3. # 8
