1. mesquite
  4. Tuesday, 24 October 2017
When using the J51 Layer Slideshow module, I cannot get it to view in [showcase] position on the Maya template. However it works in other positions? Not sure what the reason would be and I can't see an obvious fix. Any ideas?
Thanks,
Terry
Hi Terry
.copyright p {
color: #fff;
opacity: 1;
That's done it. Great.
Just a quick question whilst i'm here, can I change the colour of the copyright info using CSS?
Thanks,
Terry
Hi Terry
Navigate to the 'Module Widths' tab of your template settings and ensure that you have enabled both the 100% Width and Remove container padding options for this module position.
Hi Ciarán,
Yes, [showcase-1a] does work but does not span the full width of screen which is what I'd like it to do.
Please see url:
http://www.dontelsupplies.co.uk/
Thanks,
Terry
Hi Terry
Have you tried using position [showcase-1a] instead?
