1. mesquite
  4. Tuesday, 24 October 2017
When using the J51 Layer Slideshow module, I cannot get it to view in [showcase] position on the Maya template. However it works in other positions? Not sure what the reason would be and I can't see an obvious fix. Any ideas?
Thanks,
Terry
Hi Terry
Have you tried using position [showcase-1a] instead?
Hi Ciarán,
Yes, [showcase-1a] does work but does not span the full width of screen which is what I'd like it to do.
Please see url:
http://www.dontelsupplies.co.uk/
Thanks,
Terry
Hi Terry
Navigate to the 'Module Widths' tab of your template settings and ensure that you have enabled both the 100% Width and Remove container padding options for this module position.
That's done it. Great.
Just a quick question whilst i'm here, can I change the colour of the copyright info using CSS?
Thanks,
Terry
Hi Terry
.copyright p {
color: #fff;
opacity: 1;
