I get an error message directly on startup under localhost.
This means that the created database is not or no longer being accessed.
			- waldiwhz
- Friday, 29 December 2023
the installation of the template Layla under Joomla 4 works.
Thank you for your help.
walter
walter
Did you try if it works? I get an error when installing: Duplicate entry '700-4.4.0-2023-09-13' for key 'PRIMARY'
The Website is installed though - but no user is generated, so you cannot login.
Andreas
Andreas
				I hope to have just applied a fix for both the Layla and Emani templates for this issue.To obtain the fix, you can re-download your template from your Joomla51 template downloads.
We have been able to replicate this issue with the Emani template installer. We are working on a fix for both templates and will have a solution shortly.
Exactly the same problem with the EMANI-QuickStart installation for Joomla 4.
Error: Call to a member function load() on null.
Please check.
Please check.
Difficult to say what may be causing this issue as we are currently unable to replicate, however, I have just updated to the latest Joomla version and rebuilt the demo installer for this template which should hopefully resolve this issue. To obtain simply re-download from your template downloads.
the issues is:
			the issues is:
Could you please detail the error message you are getting? Admittedly, we use Xampp in development and I've just tested the demo installer for the Layla template without any issues.
- # 9
