I get an error message directly on startup under localhost.
This means that the created database is not or no longer being accessed.
			- waldiwhz
- Friday, 29 December 2023
Could you please detail the error message you are getting? Admittedly, we use Xampp in development and I've just tested the demo installer for the Layla template without any issues.
the issues is:
Call to a member function load() on null.
			the issues is:
Difficult to say what may be causing this issue as we are currently unable to replicate, however, I have just updated to the latest Joomla version and rebuilt the demo installer for this template which should hopefully resolve this issue. To obtain simply re-download from your template downloads.
Exactly the same problem with the EMANI-QuickStart installation for Joomla 4.
Error: Call to a member function load() on null.
Please check.
Please check.
We have been able to replicate this issue with the Emani template installer. We are working on a fix for both templates and will have a solution shortly.
				I hope to have just applied a fix for both the Layla and Emani templates for this issue.To obtain the fix, you can re-download your template from your Joomla51 template downloads.
Did you try if it works? I get an error when installing: Duplicate entry '700-4.4.0-2023-09-13' for key 'PRIMARY'
The Website is installed though - but no user is generated, so you cannot login.
Andreas
Andreas
the installation of the template Layla under Joomla 4 works.
Thank you for your help.
walter
walter
- # 9
