Hi Rolf
moving the custom.css file to the «old» location might work. I just wanted to report this issue to Ciaran, because there is a note
If you find you have a large amount of Custom CSS in the field above, you can copy it's contents to your templates custom.css (../media/templates/site/[YourTemplate]/css/custom.css) with the same effect. Ensure to first enable the custom.css option below.
in the template settings. I am hesitating to try your solution, since using the «Custom CSS» works as well.
My impression is, that the decision of the Joomla team to change the location for saving CSS files
- old: /templates/template_name/css (Joomla 3.x)
- new /media/templates/site/template_name/css (Joomla 4.x)
is causing a lot of trouble all over the world and I do not really see an advantage of the new path.
Thank you and kind regards
Chris
