I am using J51_Kindle for my site: sdccontracting.ca
I cannot get it working on my iPhone and iPad properly. I have set it to be responsive design and it is still not optimising. I have text overlapping, images failing to show and or resize. The light box does not work on mobile etc.
Any help with this would be great.
- mmayer
- Monday, 06 June 2016
I solved the problem by changing the settings for the top-modules container (Padding bottom)
Juergen
Juergen
Updating your template to the latest download should resolve these issues. For details on updating your template may I suggest the following article... http://joomla51.com/tutorials/item/updating-your-template
I am still getting the same errors after the upload of the new template.
Text overlapping, and or not resizing to mobility optimization.
Also, when I click on images using the J51_ThumbsGallery, the lightbox turns dark, therefor you cannot see the images. This is happening on the desktop.
Also,
lightbox does not work on mobile, or images are not swipable when using thumbs gallery. they open in new window.
We are unable to replicate your issue with overlapping text on your homepage. Would you have a URL directly to an example of this issue or post a screenshot displaying an example of the issue?
Regarding your thumbsgallery try updating to the following.. http://www.joomla51.com/free-module-extensions/item/j51-thumbs-gallery . To update simply install the download via the extensions manager.
sdccontracting.ca
Please check using a mobile phone - iPhone.
You will see the overlapping text in header etc.
Also, any thoughts on the lightbox greying out?
As detailed updating the thumbs gallery module to the following will resolve the lightbox issue.. http://www.joomla51.com/free-module-extensions/item/j51-thumbs-gallery
To resize your logo text on smaller screen try adding the following to the Custom CSS field of your templates parameters (edit to taste)...
h1.logo-text a {
font-size: 36px;
}} Ciarán
I also had trouble with the ThumbsGallery photos being grayed-out / cloudy -
so I downloaded the more recent version of the extension and that fixed the problem.
T
T
- # 9
Hi Ciarán,
I also have problems with Kindle not being mobile-friendly, I followed the instructions in post #22325 about updating the template but I could not see a download link in my download area, although some of my other templates are available for download.
In my purchase history area I can see that I purchased Kindle and it says status expired for Kindle on the on the same day as I purchased the template.
If the issue is an outdated template and not my settings do I have to re-purchase to get an updated version of template that works correctly?
- # 10
Hi Jude
The latest download of our Kindle template should be now available for you to download.
- # 11
Many thanks for enabling the download of the Kindle update Ciarán.
I have another site which Google is flagging as not mobile-friendly. This one was using Letterpress version 1.0 dated June 2013. I did have access to a download of this so updated the template to version 1.2 dated June 2013.
After the update of the template the site is however still being flagged as not mobile-friendly.
Before I go any further with this can you please confirm that version 1.2 (June 2013) is the latest version of Letterpress?
- # 12
Hi Jude
Over time we do apply minor fixes to template which may not always warrant a change in version number. Presuming you haven't made any changes to the core template files I would suggest installing the latest download of the template (http://joomla51.com/tutorials/item/updating-your-template).
- # 13
Yes, thank-you Ciarán, making a fresh download from my download area a couple of days ago is what I did before I posted.
When I installed that version it showed in my manager as being built in 2013. As I was still having non-mobile-friendly issues I was asking if there was a more recently modified version than 2013 available.
- # 14
Hi Jude
Would you have a URL to your site and we will examine what may be causing these issues?
- # 15
Hi Ciarán,
That is not necessary as you have resolved my questions in a different post:
https://www.joomla51.com/forum/8-commercial-templates/9049-letterpress-not-mobile-friendly-robots-txt/23983
Thanks very much for your replies
- # 16
because I also have some problems with the Kindle Template in den Mobile Version, could you please give me the information if I used the recent Version being 2013 or is there meanwhile a updated version available????
Thanks in advance
Juergen
Thanks in advance
Juergen
- # 17
Hi Juergen
Please include a URL to your site and details on the issues you are having.
- # 18
https://www.werbe-sieger.de
here I have a Problem with the mobile menue, cannot open any menue item!!
Juergen
Juergen
- # 19
Thank you Juergen
Updating your template to the latest download should resolve this issue for you (https://joomla51.com/tutorials/joomla-basics/updating-your-joomla-template). The latest download should be now available to you (Profile -> Downloads).
- # 20
- 2
