I have a problem with the presets.
Under Details -> Load Presets I select a preset and load it.
The preset is loaded and everything works fine up to this point.
If I then enter some custom code or make another change and click on save, the default preset is automatically loaded again.
Is this correct and am I doing something wrong or is it a bug?
Kind regards
Olaf
