Hello Ciaran
I have three problems in the London template with j51 icons plugin and font awesome.
1. in a custom module the font awesome are not loading, also after adding a cdn link. The 7 Stroke icons will work.
2. How can i set the Icon title behind / on the right to the font awesome icon, not under the icon as it is the standard?
3. The icon alt text is always showing, not as it should be, only at mouseover. i set a custom code with display:none, but now also on mouseover the alt text doesnt appear.
In the sample URL you can see it in German language in the Login Module.
Thank you,
Steve
