1. Stefunk
  4. Monday, 16 April 2018
Hello Ciaran
I have three problems in the London template with j51 icons plugin and font awesome.
1. in a custom module the font awesome are not loading, also after adding a cdn link. The 7 Stroke icons will work.
2. How can i set the Icon title behind / on the right to the font awesome icon, not under the icon as it is the standard?
3. The icon alt text is always showing, not as it should be, only at mouseover. i set a custom code with display:none, but now also on mouseover the alt text doesnt appear.
In the sample URL you can see it in German language in the Login Module.
Thank you,
Steve
  1. https://ducatus.biz/de
1. May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
2. To amend you can add the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)...
.j51_icons92 .j51_icon {
display: flex;
align-items: center;
justify-content: space-between;
3. We are unable to replicate this issue. Maybe we are looking at the wrong module (sidecol - Login)?
