1. crimle
  4. Friday, 22 November 2024
I am using J51_Emani_J4_2.0.0 on one of my websites. We are trying a 2-columns blog-layout. The first column is ok. But the second column does not respect the max-width of the template. The second column protrudes over the edge of the main content.
This issue is similar to an issue with J51_Skylar I reported earlier. So I tried the solution you provided in that thread, but it does not work here. I added the following to the Custom CSS field of the templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.blog-items.columns-2 {
grid-template-columns: 50% 50%;
.blog-items.columns-3 {
grid-template-columns: 33% 33% 33%;
Please give me a hint how to resolve this issue.
Thank you and kind regards
Chris
  1. https://art2o.ch/en/ and also https://art2o.ch/en/gallery-en/videos
Hi Chris
Could I you check the URL provided as it appears to give us a 404 error.
sorry for this. I filled two URLs into the field, so it causes an error. Please try
and
Chris
Hi Chris
It appears that your videos are been displayed within iframes which have a fixed width and are therefore extending beyond the column width. To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
[code]iframe {
max-width: 100% !important;
}/code]
unfortunately, the code you suggested did not change anything. But then I had the idea to replace
with this
grid-template-columns: 48% 48%;
and it seems to be OK now.
Thank you anyway ;-)
Kind regards
Chris
