1. Afolo-de
  3. Thursday, 27 February 2025
I am currently redesigning our website. I want to use the Numbers module, but I get the following error
Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in ../modules/mod_j51numbers/mod_j51numbers.php on line 23
Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in ../modules/mod_j51numbers/mod_j51numbers.php on line 24
Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in ../modules/mod_j51numbers/mod_j51numbers.php on line 25
Do you have a solution for me?
  1. http://www.joomal5.beuermann-gmbh.de/
Basically, you can remove this message from the website by changing the "Report errors" setting...
Joomla backend: Configuration-> SERVER -> Set report errors to "None"...
The developer can happily tell you whether and how this can be turned off. I don't know anything about it either...
Das sind zunächst einmal nur Warnungen, die aber mit Joomla 6 zum Problem werden. Deshalb sollte Ciaran die veralteten Funktionen durch die entsprechenden neuen ersetzen.
