1. Afolo-de
  3. Thursday, 27 February 2025
I am currently redesigning our website. I want to use the Numbers module, but I get the following error
Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in ../modules/mod_j51numbers/mod_j51numbers.php on line 23
Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in ../modules/mod_j51numbers/mod_j51numbers.php on line 24
Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in ../modules/mod_j51numbers/mod_j51numbers.php on line 25
Do you have a solution for me?
  1. http://www.joomal5.beuermann-gmbh.de/
Das sind zunächst einmal nur Warnungen, die aber mit Joomla 6 zum Problem werden. Deshalb sollte Ciaran die veralteten Funktionen durch die entsprechenden neuen ersetzen.
Basically, you can remove this message from the website by changing the "Report errors" setting...
Joomla backend: Configuration-> SERVER -> Set report errors to "None"...
The developer can happily tell you whether and how this can be turned off. I don't know anything about it either...
