1. noelada
  3. Tuesday, 21 February 2023
This behaviour is caused by css appearance: none; . Overriding it to appearance: auto; restores the down arrows.
Cassiopeia works OK without any custom CSS.
Thank you Ciaran,
The template we are using is MagnoliaJ4. Could you please make the same change as you did for Layla.
Regards,
Noel.
PS: The change for Layla resolved the issue. - Thanks.
Hi Noel
We have just updated the Magnolia template with the same fix.
Thanks Ciaran,
Works well.
Incidentally, if in Main Menu you select system links - Menu Heading the menu text gets changed to upper case on the menu. The system links - separator works OK. This issue is for Magnolia but may be a general problem.
Regards,
Noel.
We are using separator so this is not an issue for us.
We've just bought the J4 version of our Maya template and experiencing the same problem. Would it be possible to have fix it also for this package ?
Thanks,
Grégoire
HI Grégoire
This fix should be already applied to the Maya template. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Thank you for reporting this issue. This was a template issue which we have since been able to replicate.
Thank you for the fix. I've updated the template but I still have the same problem.
Did I miss something ?
I sent you an email with some further details.
Thanks for your help.
Laurent p/o Grégoire
Friendly bump
Hi Laurent
Could I ask you to try downloading and installing one more time? I may have missed something with th is update.
I tried updating myself however there appears to be an upload size limit with the details provided.
Thank you for the time spent and sorry for the upload size limit : it's a dev site not optimized.
Indeed, I made a new update and the result is far much better.
However the look and feel is not the usual "chosen" one we have on J3. But may be it's "normal" ?
Here are the differences. But we can live with them ! :-)
Thanks for your support,
Regards.
Hi Laurent
Yes unfortunately we are limited in what we can do with the style change. The 'Chosen' library used in Joomla 3 core has been replaced with a Bootstrap 5 alternative. I believe this was due to Chosen Js needing jQuery (https://harvesthq.github.io/chosen/).
