I am just working on Impulse template for a new project. Have following issues pls:
1) Background size - what is the best size for this image? I notice that even your demo does not stretch all the way across on the ipad mini (landscape).
2) Fitting ipad mini (landscape) - the tail end of my menu (right hand side) is off screen so the whole thing is not adapting to the correct screen size. It is better, but not perfect, in portrait.
3) Responsive - my responsive menu is only showing the top half of the word 'Home'
4) Background IE8+9 - my background image gets crunched (height-wise) with IE8+9. I tried a fix you had posted - #body_bg {background-size: auto !important;} - but it does not change the height issue. I see it happening with your demo too but is less obvious due to your choice of background image.
Could you pls let me know if there are any fixes to the above - I love the template by the way except for these niggles.
Thanks very much
all the best
Chris
