1. kaiserf
  4. Monday, 16 April 2018
Hello Ciarán,
I use the template harmony. We have incorporated on the page https://www.salzstiegl.at/de/ Header Images. Now to my question: In the mobile view, the background images are not scaled. My client does not want to install a slider because he likes the variant very much. How can I scale the header images in Responsive Design? Is there a solution at all?
Thanks for your help
Franz Kaiser
Hi Franz
Does changing the suggested CSS to the following help in any way?...
#container_header {
height: auto !important;
min-height: auto;
padding-top: 50%;
.header-3 {
top: 0;}
Hello ciaran,
I send you the access data per mail.
Franz
Would you have a direct URL to an example of this issue? We are currently unable to replicate on any browser with your site.
Hello Ciarán,
I tried a lot now, but unfortunately with this code the menu bar is moved down. Unfortunately that does not look very good.
Is there still another solution?
LG Franz
Hi Franz
To amend you can add the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)...
#container_header {
min-height: auto;
padding-top: 50%;
Does this give you the desired result?
