1. kaiserf
  4. Monday, 16 April 2018
Hello Ciarán,
I use the template harmony. We have incorporated on the page https://www.salzstiegl.at/de/ Header Images. Now to my question: In the mobile view, the background images are not scaled. My client does not want to install a slider because he likes the variant very much. How can I scale the header images in Responsive Design? Is there a solution at all?
Thanks for your help
Franz Kaiser
Hi Franz
To amend you can add the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)...
#container_header {
height: auto !important;
min-height: auto;
padding-top: 50%;
Does this give you the desired result?
Hello Ciarán,
I tried a lot now, but unfortunately with this code the menu bar is moved down. Unfortunately that does not look very good.
Is there still another solution?
LG Franz
Would you have a direct URL to an example of this issue? We are currently unable to replicate on any browser with your site.
Hello ciaran,
I send you the access data per mail.
Franz
Hi Franz
Does changing the suggested CSS to the following help in any way?...
#container_header {
min-height: auto;
padding-top: 50%;
.header-3 {
top: 0;}
