1. Ale
  4. Wednesday, 11 November 2015
In the habitat template example, the menu is still on the top the web page when I scroll down.
Look in my web: http://www.karnivoro.cl/ the menu is disappears when I scroll down. :(
Thanks.
As the issue appears to be only present on your homepage, ensure that jQuery is disabled within all your homepage modules as this is already loaded by Joomla. Multiple copies of jQuery loaded is the most common cause for such issues.
Alternative you can install the 'jQuery Easy' plugin to ensure only one copy of jQuery is loaded across your site.
Thank´s Ciaran. It work.
I dissable jQuery in J51_SlideshowModule.
Regards!
When I dissable jQuery in J51_SlideshowModule the menu is still on the top the web page when I scroll down, but the slideShow is hide.
Regards...
Ok Ciaran, no problem... I send to you the acces. :)
Regards,
Thank you Ale
I have installed and setup the 'jQuery Easy' plugin for you which allows for better handling of jQuery throughout your site. Your slideshow and menu are now displaying correctly.
