1. bibbp
  4. Sunday, 12 February 2017
Ciaran,
I have a white background on the serenity template, and the footer text therefore needs changing. I have tried:
#footermenu ul li a {
color: #555555 !important;
...but it is just not working. It is still white on white. Any suggestions?
Peter
  1. https://dayservices.scottsproject.org.uk/
The CSS you have used is correct. Presuming that you have multiple template styles, check that you have added the Custom CSS to the correct template style for your homepage.
I have just one template, so maybe there something else in the custom CSS which is causing the problem:
body {
background-image: url(images/web/Footer_Butterfly.png);
background-repeat: no-repeat;
opacity: 0.8;
background-position: left;
.item-101.active {
background-image: url("https://dayservices.scottsproject.org.uk/images/web/Roof.png";);
background-position: 15px 0px;
.item-121.active {
.item-122.active {
.hornavmenu {
left: 274px;
position: relative;
text-align: left;
margin-top: 50px;
.maincontent {
margin-top: 50px;
I think it might be something to do with the additional margining I've used to lower the menu...
Nothing there that should cause you any issues. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
All should be well now. Your issue was the '.maincontent' property ending in a '(' rather than a '{'. Always the little things! :)
Magic. Sincerest apologies for my elementary error!
