1. bibbp
  4. Sunday, 12 February 2017
Ciaran,
I have a white background on the serenity template, and the footer text therefore needs changing. I have tried:
#footermenu ul li a {
color: #555555 !important;
...but it is just not working. It is still white on white. Any suggestions?
Peter
  1. https://dayservices.scottsproject.org.uk/
Magic. Sincerest apologies for my elementary error!
The CSS you have used is correct. Presuming that you have multiple template styles, check that you have added the Custom CSS to the correct template style for your homepage.
I have just one template, so maybe there something else in the custom CSS which is causing the problem:
body {
background-image: url(images/web/Footer_Butterfly.png);
background-repeat: no-repeat;
opacity: 0.8;
background-position: left;
.item-101.active {
background-image: url("https://dayservices.scottsproject.org.uk/images/web/Roof.png";);
background-position: 15px 0px;
.item-121.active {
.item-122.active {
.hornavmenu {
left: 274px;
position: relative;
text-align: left;
margin-top: 50px;
.maincontent {
margin-top: 50px;
I think it might be something to do with the additional margining I've used to lower the menu...
Nothing there that should cause you any issues. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
All should be well now. Your issue was the '.maincontent' property ending in a '(' rather than a '{'. Always the little things! :)
